hi all,
ive changed the cranck and cam trigger on my evo 7 to an -18 and single point on the cam.
ive got full 720 sync and checke'd the timing ofset with a timing light.
now all is functioning and well but the car stals when stopping at a trafic light and has NOOOOO power.
the last time the car was calibrated and on the dyno it had the origional cranck and cam trigger not sure if it was synced, ive held a timing light on it while it was on the dyna, but i cant find an ofset in the software .
not at ''defined sensors/cranck sensor''
is it possible that now the car has a ''propper' trigger system the timing is off?
with kind regards maarten tiemessen
evo 7 trigger change
Re: evo 7 trigger change
"ive got full 720 sync and checke'd the timing ofset with a timing light."
So are you saying that timing is correct or incorrect now ?
Who set the calibration for the new trigger wheels, if they were unable to actually set it up correctly that you now wish to change something ?
And you are unsure if it was ever correct ?
https://youtu.be/xQcv9YK-DQ0?t=490
