Any dealer here that can help me ?? @riceracing
Great points agree with all of them, especially the pressures 'claimed'. I think I am on the extreme end (read mental!) of flows in use, and pressures are nothing like what is on the packet! I always measure pressure nearer the end of the discharge nozzles.stevieturbo wrote: Mon Jan 31, 2022 8:08 am Pump current at any given time will depend on pressure it is generating for the most part.
Work it harder, it will draw more current.
I did scope mine a while back, but pretty sure it was fairly low. That said, given what I am trying to flow, pump would max at around 150psi.
Will check logs later when I'm home.
Don't believe all these 200psi etc claims unless you're running very small nozzles.
I pwm a small 15A rated SSR and it seems fine.
Although there are bigger pumps out there.
I assume syvecs have incorporated flyback protection within their controller so a pump can be run directly Peter ?
I know I tested my SSR with and without and things were happier with it.
