This Link - CLICK HERE is for version 1.711 of the S7 firmware. RIGHT CLICK AND COPY LINK IF DOESN'T AUTOMATICALLY DOWNLOAD
Changes Since 1.699
702
705
706
launchState should read identically to before. launchStateX should read the same as the old except in stage, where it has a different value  (please log both to compare):
708
We then have
709
710
711
						Latest S7 Firmware
Re: Latest S7 Firmware
This Link - CLICK HERE is for version 1.752 of the S7 firmware.
Changes Since 1.711
* Aircon PWM output
750 -
tbvDuty available as cm axis
Changes Since 1.711
* Aircon PWM output
750 -
This Link below is for version 1.756 of the S7 firmware.
https://www.syvecs.com/downloads/S7v1-756-1.exe
Changes Since 1.752
* CAN Logging in SCAL, outputs log in .ASC format. Only Available Internal CAN and CAN2
Changes Since 1.752
This Link below is for version 1.761 of the S7 firmware.
https://www.syvecs.com/downloads/S7v1-761-1.exe
Changes Since 1.756
* rev limit DBW limit range multiplier becomes f(revLimitRpm,gear)
Note Limiters / Rev Limit / Drive By Wire Closing / DBW Target Limit Range Multiplier WILL NOT IMPORT AUTOMATICALLY on a calibration upgrade due to the change of map axes. You will need to copy values across manually if you are already using this function.
* Tolerance for brief sensor errors in SBV control
Very short supercharger bypass valve position sensor errors may now be tolerated without shutting down the control, similarly to throttle position sensor error tolerance in drive-by-wire.
* Paddle shift upshift may be denied on low pedal position (ppsFinal)
* Slave link can return btPwr1V instead of mappable input voltage
When an ECU is operated as a slave, one of the up-to-28 pin voltages returned may be overridden with a board temperature sensor voltage, for which a user-defined sensor can be created at the master if desired, with linearisation (0.25V@-25C to 1.75V@125C). This can be useful in particular if the slave has been sited in a hotter location than the master.
* Gap validation is on by default when new calibrations are created, and now described as recommended in help notes
* Additional diagnostic items sstPeak, sstAvg have been added
* astPeak, astAvg, sstPeak, sstAvg are now mandatory to log at 1Hz
* "(Page Up / Page Down)" added to names of 4D maps (fuel cyl trim / fuel mlt load / ign add load)
* f1 help on wgp-based wastegate control staged map limit
* some wastegate map renaming /reordering for clarity
* second wastegate control staged map target limit calibrations, switched on calselect
* clamp engTrqEstMbt at engTrqEstFriction plus... becomes f(gear)
* calibratable pps learn low and high stop values (instead of hard-coded 0% and 100%)
* improved calculation of learned-pps linearisations
* fuelPump1A/1B pwm outputs, with independent output type, frequency, fixed mode duties, output duty linearisations
Now have the ability to have 2 PWM Fuel pump outputs and can control the sequence of duty for each
* second closed loop pwm function (clpwm02)
* five more 3D CMs (CM316-CM320)
* LMP pit limit fuel severity adder for egt always applies ("in" as well as "out")
* ability to select LMP pit limit control map sets 1/2/3/4 manually by pitswitch
* add gearBlipStartV/gearBlipTargV monitoring items
* gear blip gear and closed loop start position taken automatically from gear captured at start of paddle shift actions
* add option for gear blip startV to be live or in-gear default
* update closed loop cut and blip f1 help to comment on use of paddle shift gearVF capture
* under surface update to allow 2 DI Pumps on V12 engine with 3 or more lobes
* Idle Learn improvements with reduced learn rate option and idle duty learn sweep enable/disable
Changes Since 1.756
This Link below is for version 1.765 of the S7 firmware.
https://www.syvecs.com/downloads/S7v1-765-2.exe
IMPORTANT Watch the Help video on the new firmware here https://youtu.be/IQJoXUhDBxc
Changes Since 1.761
* renaming for the two user timers and improved renaming for the basic PWMs and closed-loop PWMs
* full re-write of the cruise control and associated functions for switch inputs etc, plus driveRatioErrorPct (driveRatioError/driveRatioExpected) and driveRatioVS/driveRatioVSError/driveRatioVSErrorPct calculated from vehicleSpeed.
Changes Since 1.761
