Latest Base Map
Technical Help / Firmwares for the Infiniti Q60 Awd Controllers
Locked
Latest Base Map
The latest Infiniti AWD Base map which matches the latest firmware can be found below in Attachments
AwdBase_QX60 1.15.SC
(38.8 KiB) Downloaded 3847 times
1.18
AwdBase_QX60 1.18.SC
(42.89 KiB) Downloaded 4173 times
1.21 Base Map
For use with 1.21 Firmware
AwdBase_QX60 1.21.SC
(46.26 KiB) Downloaded 4109 times
1.23 Base Maps
For use with 1.23 Firmwares
AwdBase_QX60 1.23 X4.SC
(51.46 KiB) Downloaded 3968 times
AwdBase_QX60 1.23.SC
(51.46 KiB) Downloaded 3661 times
1.24 Base Maps
For use with 1.24 Firmwares
AwdBase_QX60 1.24 X4.SC
(55.78 KiB) Downloaded 4079 times
AwdBase_QX60 1.24.SC
(55.83 KiB) Downloaded 3654 times
1.25
AwdBase_QX60 1.25 X4.SC
(61.05 KiB) Downloaded 3776 times
Re: Latest Base Map
For use with 1.27 Firmwares
AwdBase_QX60 1.27 X4.SC
(66.87 KiB) Downloaded 1878 times
AwdBase_QX60 1.27.SC
(66.84 KiB) Downloaded 1819 times
Re: Latest Base Map
For use with 1.28 Firmware
AwdBase_QX60 1.28 X4.SC
(72.44 KiB) Downloaded 1610 times
Re: Latest Base Map
1.29 base map
AwdBase_QX60 1.29 X4.SC
(72.89 KiB) Downloaded 1534 times
Locked
