Hi
Does anyone know if the 'learn' maps (For idle base duty, knock/cylinder trim, WG duty etc) can be committed to their respective base map or do they just exist as separate constantly changing maps? Other ECU's I have used allow you to commit to the base map and zero out the learn map, wondered if you can do this on the syvecs.
						Learn Maps - committing to base maps?
Re: Learn Maps - committing to base maps?
Hi
When you are viewing the actual learning correction map (e.g. Base Wastegate Control Duty Learning / Learned Correction 1) you can use the Learn menu (top right) to apply or reset the learned correction to the base map.
Thank you! I missed that feature.
You can use the Learn menu (top right) to apply or reset the learned correction to the base map.
After covit, my need to travel is also growing. I mostly use the map to locate the best direction for myself classic games Spades
