I'm trying to learn and understand how my ECU and subsequent map has been configured.
The Lambda is narrow band and shows as connected, but I am only 99% sure it isn't being used for corrections in any point in the calibration.
My reasoning, is under: Run-mode Fuelling/Corrections/Closed Loop Lambda/Overall Enable is set to Disabled
with this disabled, I believe the lambda readings are not used to determine any fuelling, no matter what the CAL switch etc is set to.
Is this theory correct?  or can it be overridden on an individual basis somewhere else in the config?
Thanks for any help.
						Is my Lambda being used?
Re: Is my Lambda being used?
If it is disabled, then no corrections will be taking place.
I don't even think very many would even try using a narrowband sensor, nor would you want to really.
Get a NTK wideband
Get a NTK wideband
Many thanks for the reply.
				CandiceCole
it appears that your ECU's closed-loop lambda control is disabled. Closed-loop lambda control uses the lambda readings from the oxygen sensor to make fueling corrections in real-time. With the "Overall Enable" set to "Disabled," it suggests that the lambda readings are not being used to determine fueling corrections.
							If you want to find your own entertainment applications, you can refer to the Getmodnow website, which is safe and free.
I also think the lambda index is not being used correctly.it appears that your ECU's closed-loop lambda control is disabled. Closed-loop lambda control uses the lambda readings from the oxygen sensor to make fueling corrections in real-time. With the "Overall Enable" set to "Disabledbackrooms," it suggests that the lambda readings are not being used to determine fueling corrections.
				lilycollins9x
Yes, you're correct.thomasfrank wrote: Mon Mar 25, 2024 3:16 am Yes, your theory is correct. In most engine control units,incredibox when the Closed Loop Lambda Overall Enable setting is disabled, it means that the ECU is not using the lambda readings to make fueling corrections.
