Latest Firmware Releases
Technical Help / Firmwares for the Corolla GR Awd Controllers
Locked
Ryan.g
Syvecs Staff - Caretaker
Post by Ryan.g »
Version 1.25 is the first release of the CorollaGR Firmware
Firmware Version 1.25 - www.syvecs.com/downloads/X4AWD_Corolla_1-25-1.enc
Ryan.g
Re: Latest Firmware Releases
Post by Ryan.g »
Changes since 1.25.1:
* Added LatG Duty Adjustment
Firmware Version 1.27 - www.syvecs.com/downloads/X4AWD_Corolla_1-27-1.enc
Ryan.g
1.29 Firmware Release
Post by Ryan.g »
Changes since 1.27.1:
* USB Datalogging
Firmware Version 1.29 - https://www.syvecs.com/downloads/X4AWD_ ... 1-29-1.enc
Ryan.g
Post by Ryan.g »
Changes since 1.29.1:
* Enable Load for Steering Angle Multiplier
* Option for AN1 to be BurnOut Switch or TransferCase Temp
* Transfer Case Temp Linearization and Limp
Firmware Version 1.34 - https://www.syvecs.com/downloads/X4AWD_ ... 1-34-2.enc
Locked
