My project (405 mi16 with turbo) is now on good situation (been on the road for ten years but on this year I have done everything again: engine, electrisity etc.) and I am starting to connect my S6. This is my first time to do all connections by my self (time to learn) and my knowledge is quite poor..
 I had DTA for some years and it was quite simple to connect (had simle intructions). S6 is just too much to my knowledge and I need many advice. Pins does not tell me much on S6 pinout.
Lambda, Lan, EGT, Knock, ignition ja injection connections are clear to me
 Questions:
1. Where to connect CAL-switch (black and white wire) ?
2. Where to connect 2-pin sensors as (watertemp, oiltemt, airtemp) ?
3. Is camshaft HALL sensor => 5Vout and AV1-4 ?
4. Throttle => 5Vout, ANGND2, AV1-4 ?
5. VR sensor => AB1-4, ANGND1 ?
6. Map sensor => 5Vout, AV1-4 ?
7. Fuelpump relay => ???
8. Boost control Valve => ???
9. TPS 3-pin Bosch version => ???
10. RPM out => ???
-Mikko-
 (worked fine on Apexi AVC-R) and there is magnet on the wheel and the sensor which reads magnet (I guess like HALL sensor ? ). Sensor have two wire (ground and signal) so where do I connect wires ?
