The latest VAG MQB4 AWD Base map which matches the latest firmware can be found below in Attachments
MQB4 is only available on the X4 Hardware
This base map limits the Max duty to 70%, Some users of the Rs3 Kit from Iroz motorsport have the duty limits at 80% or even 90%. You will need to adjust in Scal to Suit
Latest Base Map
Latest Base Map
- AwdBase_MQB4 1.24 X4.SC
- (55.78 KiB) Downloaded 2258 times
1.25
- AwdBase_MQB4 1.25 X4.SC
- (61.05 KiB) Downloaded 2507 times
Re: Latest Base Map
- AwdBase_MQB4 1.27 X4.SC
- (66.87 KiB) Downloaded 494 times
Re: Latest Base Map
The latest VAG MQB4 AWD Base map which matches the latest firmware 1.28 can be found below in Attachments
- AwdBase_MQB4 1.28 X4.SC
- (72.44 KiB) Downloaded 194 times
Re: Latest Base Map
The latest VAG MQB4 AWD Base map which matches the latest firmware 1.29 can be found below in Attachments
- AwdBase_MQB4 1.29 X4.SC
- (72.89 KiB) Downloaded 277 times
Re: Latest Base Map
Thank you very much for providing the details of the latest base map for VAG MQB4 AWD, suitable for firmware 1.29. This is a handy guide, especially with the note about the 70% maximum duty limit and the need for customization to suit the vehicle configuration.Ryan.g wrote: ↑Fri Apr 19, 2024 1:06 pm The latest VAG MQB4 AWD Base map which matches the latest firmware 1.29 can be found below in Attachments
This base map limits the Max duty to 70%No Internet Game
