GR Yaris PnP Kit Installation Problem
For Toyota Technical Chat.
ml27
Post by ml27 »
Hi guys,
I'm new to Syvces. I finally received the ECU and get it installed last week. We installed the it as per the Syvces manual and we were able to get the engine up and tuning. However, the dashboard pops up a bunch of malfunction messages and all the warning lights are on and the tachometer, speedometer and indicator are not working. Please see the attached photo which I took it while the engine is running. What could be wrong and how can I fix this?
Thanks in advance.
ML
Syvecs Ed
Syvecs Staff - Cleaner
Re: GR Yaris PnP Kit Installation Problem
Post by Syvecs Ed »
Do you have the dash can and loom kit fitted? Or have you just plugged in the ECU?
superedan
Post by superedan »
Use an OBD-II scanner to read the codes. Research the specific codes to diagnose the issue, which might be related to improper connections or settings that need to be adjusted in the software. Drive Mad
superedan wrote: Thu Oct 31, 2024 7:50 am Use an OBD-II scanner to read the codes. Research the specific codes to diagnose the issue, which might be related to improper connections or settings that need to be adjusted in the software. Drive Mad
no doubt spam
