The Syvecs S7I and S7Plus GP ECU's can now be loaded with a Generic firmware Build to allow custom control of the CAN RX into the ECU allowing users more flexibility with the CANbus.
The Transmit is also flexible now with custom options for CAN identifer, Speed, Endian, Data etc
IMPORTANT: This Firmware is not to be used with PLUG IN KITS!!!!!
The Firmware is loaded on the USB port of the S7I and S7Plus behind the Hex Plug, A guide is found here
https://www.syvecs.com/downloads/Syvecs_Updater.pdf
Generic S7i and S7Plus Firmware here- Watch this video on how to use it - https://youtu.be/jHwrzR9PkGc
Firmware S7 1.1.2
https://www.syvecs.com/downloads/S7GPPlus_1-1-2.enc
S7I and S7Plus Generic Build - Custom RX and TX Firmware
Re: S7I and S7Plus Generic Build - Custom RX and TX Firmware
Updates:
- Renamed Torque Items to match S7
- Added DriveRation and GPS Speed
- Change Endian CAN logic for Flex Transmit
Firmware S7 1.2.1
https://www.syvecs.com/downloads/S7GPPlus_1-2-1.enc
Updates:
Firmware S7 1.2.1
Updates:
- Flex Can Transmit Change to update byte swap more logically with endian swap
- Multiplexed CAN RX and TX Messages
- Triggered CAN Transmit, CAN Messages which are sent when an Item is greater then 0... Very useful with TinyDash V2 as can make Keypad buttons on Layout 8 transmit CAN messages like for DTC clear or to a PDU
See help video on new CAN Changes here - https://youtu.be/8Yn1JitpXN0
Firmware S7 1.3.1
https://www.syvecs.com/downloads/S7GPPlus_1-3-1.enc
Updates:
Firmware S7 1.3.1
Updates:
- Flex Can Transmit Change to allow Scaling and Offset
- Flex Can Transmit Start Bit updated to Start from bit 0
Firmware S7 1.5.1
https://www.syvecs.com/downloads/S7GPPlus_1-5-1.enc
Updates:
Firmware S7 1.5.1
lilycollins9x
I appreciate you sharing this knowledge.That's not my Neighbor Such adaptable firmware updates will undoubtedly offer many opportunities for customization and system performance optimization.
