Latest Firmware Releases
The Syvecs OEX (Oe Ecu eXpander) is a powerful expander module enabling advanced after market features on existing engine management systems via CAN/CANFD communication system . By utilising the well proven Syvecs X20 hardware a version of software has been created to provide our Syvecs market leading features into the Oe Ecu eXpander package. This provides the best solution for clients needs that require to expand the capability’s of an original ecu control module or to integrate with another engine control unit (Master)
Locked
Version 1.107 is the first release of the OEX Firmware
Help on updating the firmware can found via - https://www.syvecs.com/downloads/Syvecs_Updater.pdf
Firmware Version 1.107 - www.syvecs.com/downloads/X20OEX_1.107.1.enc
Re: Latest Firmware Releases
Version 1.114 Adds the following updates:
// 1.108 - Added Bmw and Supra CAN, Added Enable for 29bit in GenericRX
// 1.109 - Added Enable RPM and Tps for External WG, Fixed RPM in Focus RS Mk2, Fixed Wheel Speeds in BMW2020
// 1.109.2 - Sensor filtering tweak
// 1.110 - Added OBD2 TX Options, Coolant Pressure limp and maps
// 1.110.2 - Output Test fix, 20, 40, 60, 80% issue
// 1.111 - Added Generic TX CAN Frames
// 1.111 - TinyDash CAN Option
// 1.112 - Change User Rename items to be more flexible
// 1.113 - WG Turbo Speed sensors added and R35GTR Custom CAN Transmit waits for RPM
// 1.114 - Turbo Speed Control in WG Strategies
// 1.114.2 - Add option for SyncState to be set from GenRX or ICan sensors if no Crank Pin is assigned, so strategies like fuel pump work
Firmware Version 1.114 - www.syvecs.com/downloads/X20OEX_1.114.2.enc
Version 1.115 Adds the following updates:
// 1.114.3 - Sensor Filtering wrong for LAM1 and LAM2 as different REP
// 1.115 - Updated Help for Crank and Cam and Fixed so AN8 + can be used for Crank and Cam
// 1.15.2 - Programming Code adjustment
Firmware Version 1.115 - www.syvecs.com/downloads/X20OEX_1.115.2.enc
Locked
Return to “OEX - Oem Ecu eXpander”
