Page 2 of 2
1.13 Firmware
Posted: Mon Jun 26, 2023 9:27 am
by Ryan.g
Version 1.13.2 contains the following updates
* Added Canam / Seadoo CAN Support
* Added Ford Mustang F150 / Mustang CAN Support
* Allow WMI Solenoid to be run lower than 25%, Now 10hz is allowed
* BugFix with WMISelect from CAN
Help on updating the firmware can found here - http://www.syvecs.com/downloads/Syvecs_Updater.pdf
Firmware Version 1.13.3 for HBR WMI - http://www.syvecs.com/downloads/WMI_1-13-2.enc
Firmware Version 1.13.3 for X4 WMI - http://www.syvecs.com/downloads/X4WMI_1-13-2.enc
Re: Latest Firmware Releases
Posted: Fri Jun 30, 2023 5:27 am
by Lqqk
Aquamist FAV works with frequency of 10hz - thankyou.
1.15 Firmware
Posted: Mon Apr 15, 2024 2:09 pm
by Ryan.g
Version 1.15 contains the following updates
* Added USB Datalogging Support - https://youtu.be/bzvMUCqiv_0
Firmware Version 1.15.1 for HBR WMI - http://www.syvecs.com/downloads/WMI_1-15-1.enc
Firmware Version 1.15.1 for X4 WMI - http://www.syvecs.com/downloads/X4WMI_1-15-1.enc
1.19 Firmware
Posted: Mon May 20, 2024 9:34 am
by Ryan.g
Version 1.19 contains the following updates
* Added new CAN Transmit and RX Options - Watch this video on how to use it - https://youtu.be/jHwrzR9PkGc
* Custom Inputs which can be used in Custom PWM Maps
* SupraBMW 2020 CAN Added
* Ford Focus Mk2 CAN Added
* Extended CAN 29Bit support in generic RX
* Fix Pull-Up issue
Please ensure you are using the Latest Ssuite software which has USB support - viewtopic.php?f=8&t=122
Firmware Version 1.19.1 for HBR WMI - https://www.syvecs.com/downloads/WMI_1-19-1.enc
Firmware Version 1.19.1 for X4 WMI - https://www.syvecs.com/downloads/X4WMI_1-19-1.enc
Posted: Fri Jun 20, 2025 6:28 am
by Ryan.g
// 1.21
// OBD2 CAN TX Options for 7E0 or 7DF selection. Some cars need 0x7DF to be sent to get replies from OEM ECU
// OBD2 Transmit Speed Option - Ability to change update speeds of OBD2 items
// Added Short/Long Term Fuel Trim monitoring
// Added Ignition Timing Monitoring
Firmware Version 1.21.1 for HBR WMI - https://www.syvecs.com/downloads/WMI_1-19-1.enc
Firmware Version 1.21.1 for X4 WMI - https://www.syvecs.com/downloads/X4WMI_1-19-1.enc
