Re: MKIV Supra VVTI now working
Posted: Mon Jan 26, 2009 11:33 pm
				Steve,
I didn't check out the cold start this morning because I knew that version 1.5.1 of the control code was imminent and it will have a profound effect on the cold running of the engine (for the better, or at least that's the idea), no point in trying to make it work well on 1.3.2 when a lot of that work would need to be re-done on 1.5.1. The 1.5.1 firmware wasn't ready until after 4PM and I was still busy with other stuff, so I'll have to upgrade the firmware and do the final check in the morning.
There are still a few things that Ryan needs to do to the car, but they don't require it to be at the workshop, so you'll be free to take it away You'll need to liaise with Ryan as to when he'll be free to do those jobs...
 You'll need to liaise with Ryan as to when he'll be free to do those jobs...Cheers,
 I tweaked the opening time compensation table and it was much better. It's still a little wooly for the first few seconds until there is a little background heat in the engine, then it seems fine. Once warm it was always OK, so it's just been a case of knocking the rough edges off the warm up.
