Page 2 of 2
				Re: Changing map for bigger injectors
				Posted: Sun Jun 12, 2016 9:53 pm
				Yes...and both options take like 2 seconds lol ( ok, maybe 3 or 4 really )
Select the entire table, Maths, and multiply by 0.6 lol
restore global to 1.0
				Posted: Fri Aug 26, 2016 8:58 am
				Hodge wrote:So if I have the global at 0.6 I'm guessing if I was to adjust the entire fuel table instead I'd reduce it.  How much would you recommend Steve?
Change it back to 1.0
Then go to the fuel map.
Hit key letters S then A (select all) then hit M then M (math > multiply) then type 0.6 and hit enter.
This is how you do what Stevie says.
Before
After (key strokes) highlighted 9000rpm 1100mb you can see it does what you want
S>A>M>M>0.6>ENTER
Only issue with just doing this is you have to then do the other maps listed under Starting tab which have their own amounts listed in m/s, same process can be followed.
Also.... if you use a Load Multiplier don't forget to do the Secondary Load Injection Time table
