Page 3 of 4
				Re: iPhone Syvecs Display / Monitor
				Posted: Wed Jan 12, 2011 4:46 pm
				by Nodalmighty
				Have you considered the Blue Tooth angle?
				Posted: Wed Jan 12, 2011 4:49 pm
				by Wez
				Nodalmighty wrote:Have you considered the Blue Tooth angle?
If we could get a bluetooth dongle to work with the Syvecs data stream output on serial I guess it could work
				Posted: Wed Jan 12, 2011 6:20 pm
				by Nodalmighty
				To be honest of the 17 items in the stack stream only 6 can be guaranteed, 4 are near useless and the others require additional sensors to be of any use. The can bus message stream is more verbose but contains little additional info that would be of worth to your average performance car driver (most of it based on the F88 so half of it doesn't even exist on the lower end Syvecs). However, in it's ability to be user configured the can does offer a way to increase the free internal info that would be of interest to the laymen. Obviously there are propeller heads out there who want to know the ins and outs of a dogs a-hole but most would settle for info they have at least heard of before.
I've been looking into CAN SPI modules that use the microchip MCP2515 as a base which offer a cheap interface to a micro controller, not that this will help you (unless I convert the packet stream to RS232 and mirror it on the TX output for you but this will then need a RS232 line level converter chip to be able to use the Apple Serial lead).
				Posted: Wed Jan 12, 2011 8:12 pm
				by Wez
				The other option could be a USB to CAN adapter.
				Posted: Thu Jan 13, 2011 12:16 am
				by secure
				and this is the cheapest USB-CAN bus converter I have found
http://www.easysync-ltd.com/category/12 ... tions.html
				Posted: Thu Jan 13, 2011 8:42 am
				by Nodalmighty
Does the i-phone have a FTDI serial port simulation driver?
				Posted: Wed Jan 19, 2011 3:42 pm
				by Wez
				Look like BT may be the way forward
 Serial Bluetooth RF Transceiver Module rs232 w/ backplane
This small size Bluetooth TTL transceiver module allows your target device to both send or receive the TTL data via Bluetooth technology without connecting a serial cable to your computer. It's easy to use and completely encapsulated.
TTL data transparent transfer between a host Bluetooth device.
Works with any USB Bluetooth adapters.
Default Baud Rate: 9600,8,1,n.
Coverage up to 30ft.
Built in antenna.
Power input: +3.3VDC.
Mini Size.
				Posted: Wed Jan 19, 2011 11:04 pm
				by Johnny G
				That could open it up to other platforms for you there, Wez. You could do iPhone, Android and Win7 phone.
The BT stack on the iPhone isn't the best implementation, though. Is it still doable?
				Posted: Mon Jan 31, 2011 11:32 pm
				by Wez
				Apple are starting to wind me up, you cannot access the BT unless its a signed MFI BT device, I guess this is why the new AEM wideband app uses WiFi
				Posted: Fri Sep 30, 2011 4:14 pm
				by Johnny G
				Any movement on this?
