Hi I'm new to syvecs, I picked up a syvecs s6+ gtr plug and play kit from a buddy and was wondering if there's any reason I couldn't use this ecu as a universal option.
I would like to use this ecu in my 2000 Audi S4 which has 1.8t 4 cylinder engine swap. Is there a base map for such a set up? The crank is a 60-2 and 1 window cam sensor whicb can be easily converted to the new style multi window.
S6+ GTR plug and play kit
Re: S6+ GTR plug and play kit
I'm sure if you contact Syvecs support, someone will have something to assist getting you running.
But absolutely yes it is universal.
Or you could go through everything and configure it yourself to get running. Ultimately it will need fully configured to suit however you wire it anyway before even attempting to start.
There wouldnt be a problem configuring for your current crank/cam and a single window cam would be a little easier than a multi window anyway. But it's entirely up to you.
http://www.syvecs.com/downloads/S6Plus% ... 20Info.pdf
http://www.syvecs.com/downloads/Syvecs% ... ample.xlsx
Thanks for the reply Stevie turbo
I did speak with support which was super fast with a reply. Looks like the ECU will need to go back to be modified internally and to have the R35 can bus coding removed.
I am just waiting for a quote so I can stop by my local syvecs dealer to have it shipped back.
