				S6GP Main Connector Crimpers
				Posted: Wed Dec 26, 2018 8:21 pm
				by ders
				I've trawled the forums for this subject and have found a few close matches but none that specifically cover for the S6GP. I saw one thread which pointed to Durite 0-703-52 and 0-703-53 but I think these were for the S6+ and S8.
I'm putting together my own wiring harness and am trying to find out what crimping tools I'll need for the main ECU to loom plug for an S6GP. If anyone can shed any light on this, it would be hugely appreciated!
				Re: S6GP Main Connector Crimpers
				Posted: Wed Dec 26, 2018 11:11 pm
				For most part any decent W style crimp will work perfectly fine. S6GP and S8 would be same sort of pins. S6+ etc totally different although my link below on the DTA forum is primarily talking about the S6+ style, as most ecu's these days use the same connector. It's awkward to find that good crimper that leaves a round crimp.
But they also all have W style crimp sections on them too, and they've been very handy to have.
I'm sure it's been covered on this forum too, but I've put photos of some I've bought and used here, which are fairly cheap and do a good job of most styles of crimp. I bought all 3 types, obviously there are overlaps of what they can do.
http://www.dtaforum.com/viewtopic.php?f=9&t=16&p=14337
https://whiteproducts.com/cetools.shtml
Damned if I can recall where I bought mine though, I'm fairly sure they were bought from separate sources.
Racetronix do a couple of them, I might have bought via ebay or something. UK suppliers seem fewer though
https://www.racetronix.biz/storeitems.asp?cc=crimp-00
Ratchet crimpers are probably a good thing, but also heavy and annoying at times. The simple manuals ones here...well, they're just simple. Although the two portions of each crimp need done individually.
Proper crimpers would tend to do both at once....not all cheap ratchet crimpers will do this though. Not a big deal for a DIYer though
				Posted: Thu Dec 27, 2018 8:58 am
				by ders
				Wow, I wasn't expecting a response that fast.
Those crimpers look very similar to Superseal 1.5 but I'm sure I read somewhere that S6GP used the older Superseal 1.0 which I can't find anything for. I can just get jaw inserts for Superseal 1.5 for the crimpers I have already, but I have a niggling feeling that option may be too good to be true.
Superseal 1.5 Crimping Tool
http://www.sealey.co.uk/PLPageBuilder.a ... results=16
H2 inserts
H3 inserts
				Posted: Thu Dec 27, 2018 9:25 am
				None of the Syvecs ECUs use SuperSeal 1.5.
S6GP is Microtimer II (small terminals) and (strictly) Junior Power Timer for the large terminals (but they need seals, which aren't supplied with the terminal kit, so use Junior Timer tool instead and accept the occasional below-average crimp: or buy seals; but then the small terminals ought to have seals too!).
S6+/S6I use SuperSeal 1.0. These are not "old" and are much nicer than the rather agricultural 1.5 series IMHO!
S8 uses Microtimer 1 for small terminals, and same comment as S6GP regarding large terminals.
The Durite tools cited work well for the JT and JPT terminals, as well as the Microtimer I/II terminals. I have found no cheap tool that does the Superseal 1.0 well, but I'm sure they exist since, as Stevie says, these terminals are common to so many ECUs now (S6+/S6I, G4+, MoTeC, new Omex, etc etc).
				Posted: Thu Dec 27, 2018 9:36 am
				by ders
				Ah, ok I can see where I'm perhaps getting confused now. I'll forget what I currently have in terms of crimping tools and start anew.
Thanks for all the help guys
				Posted: Thu Dec 27, 2018 1:24 pm
				I havent tried the ones I mentioned on the S6+ pins, but as you can see in the thread, others have with good results.
Rywire or Speedwire, cant recall which...one or two of the companies in the US who sell wiring products sell some big lever arm type crimpers for the s6+ types, but pretty sure it's just a metripack crimper or something rather than the actual correct tool
I nearly did buy one once, then figured I had no real need as the little T10 etc worked just fine.
IMO the biggest hindrance with the +type pins, is using wire that's too big. Keep the wire down to a necessary size and proper thinwall cable and it's much easier to get a good crimp, and for that pin to then fit into the housing.
but the older stuff, S6, S8, most injector type terminals, AMPseap etc etc etc the little W type crimpers do work great. The crimpers with the round hole, work great to for those that require a seal in place.
If the terminals have long legs intended for a seal, I've just trimmed then down then done a W crimp again. Lets face it, the S6 and S8 housings arent particularly sealed anyway, so no need for seals on the terminals.
Even OEM ecu's using the same setup dont have seals on them.
				Posted: Thu Dec 27, 2018 9:46 pm
				by Slowie
				For larger cables on Superseal 1.0 plugs, use the following pins: Tyco p/n 3-1447221-3
They are rated at 18-16AWG cable, but I have crimped 14AWG M22759-32 cable in there no problem.
				Posted: Thu Dec 27, 2018 10:03 pm
				They're the terminals supplied by Syvecs I believe. The bigger problem is smaller gauge wire in my experience.
				Posted: Mon Jan 07, 2019 10:03 pm
				by Hugh
				The AMP pins are the same as the Motec MXXX ECU's
I bought mine many years ago, think they were Tyco Electronics Amp 58495-1 Pro-Crimpers fitted with 58495 jaws.
				Posted: Thu Jan 10, 2019 10:45 pm
				by wayneosan
				BUMP.
I just learned something today
  Thanks guys.
