This
Link - CLICK HERE is for version 1.693 of the S7 firmware.
PLEASE ENSURE LATEST SSUITE SOFTWARE IS IN USE BEFORE UPGRADING FIRMWARE!!!
http://www.syvecs.com/forum/viewtopic.php?f=8&t=122
Changes Since 1.678
Follow the firmware update guide here -
https://www.youtube.com/watch?v=Pi1pp-XbQqw&t=331s
(in 677)
(in 678)
(in 680)
* new cm map use: n2oDutyMlt
(in 682)
(in 687)
* new cm map - DBW Multiplier
* rs232 25hz transmit option
(in 688)
(in 690)
* vvt open loop switchover default values now 25000rpm
* vvt cl fail action choice of disable or open loop (default to disable)
* vvt option to retry closed loop after failure if engine restarted (required power cycle previously)
(in 693)
