Page 1 of 4
				Any possibility of Real Dash support?
				Posted: Wed Jul 03, 2019 6:41 pm
				by matt-c
				As above, many other ECU's work with Real Dash, is it something that can happen?
				Re: Any possibility of Real Dash support?
				Posted: Thu Jul 04, 2019 8:52 am
				by Trickster
				Id like to see this too, it would be nice if it worked through the pc copnnection as i run an incar pc and running an actual dash off it would be ideal
Graeme
				Posted: Wed Jul 10, 2019 2:32 pm
				by secure
				I have already contacted Syvecs about Realdash but they don't seem to bother.
but
I have succeded to stream syvecs RPM data to Realdash through Seedstudio canbus.
It was 1-2 years ago and I didnt find time to complete it.
https://www.youtube.com/watch?v=vxVyn9ecpmA
				Posted: Thu Jul 11, 2019 10:03 am
				by matt-c
				That’s interesting secure.
I actually had one of those CANbus interfaces on order yesterday but then was unsure again, mostly as i was unsure if the android usb serial interface would operate at 1mbit.
Is it a lot of work to add the other parameters?
Thinking of a team effort on this.
I’m also wondering if it’s possible to wire a Bluetooth obd reader to the ecu and access this way. Apparently this has been done to enable Haltech ecu to work with realdash and that ecu also uses a 1m bit custom can or be configured differently.
It would be awesome to have real dash working on android Headunit.
I can’t install syvecs official bt module as I’m
Out of I/o on my ecu (S6GP).
				Posted: Thu Jul 11, 2019 10:09 am
				matt-c wrote: Thu Jul 11, 2019 10:03 am
No OBD-II on Syvecs as far as I know.
I can’t install syvecs official bt module as I’m out of I/o on my ecu (S6GP).
I/O only needed for CAL switching - the telemetry data is via RS232.
				Posted: Thu Jul 11, 2019 10:32 am
				by matt-c
				Thanks Tim.
Ryan did previously confirm to me that I'm unable to install BT module, although indeed i don't need to be able to change cal via it, as of course i have the Toucan
I could possibly go Mini Expansion Unit + Syvecs Bluetooth Module + Official Android app but the cost is prohibitive for casual use.
				Posted: Thu Jul 11, 2019 10:36 am
				Out of interest, not being experienced with fancy head units, do they accept an HDMI input these days?
				Posted: Thu Jul 11, 2019 10:41 am
				by matt-c
				The android ones typically not, so you are left with HDMI to composite converters and a somewhat fuzzy display.
There are some pioneer units with HDMI in, infact my old F960BT from 2014 had this, but the display resolution was low.
Most android HU are 1024x600 , the latest ones though are 720p IIRC.
My other project is Scal on an Intel compute stick, running into the android HU via composite for now.
				Posted: Thu Jul 11, 2019 11:30 pm
				by secure
				I am not a coder. Just an arduino guy doing hobby level stuff.
It would be very easy for a software developer to do the rest of the work but I am not gonna publicate the code without auhorization of Syvecs because they may have their own policy on that. I wish they would work with Realdash so it would be alternative for us.
By the way I am running x86 based car computer.
				Posted: Thu Jul 11, 2019 11:35 pm
				CAN datastream is not a secret - the information is all there with the freely available SSuite.
