Slave Vs Fuel outputs
Posted: Fri Jul 12, 2019 1:30 pm
				I have been struggling to control the VVT solenoids well on my 2GR-FE engine.
They have been hooked up to fuel outputs, and I managed to find a PWM frequency that gave the most stable movement (240Hz) but the dynamic range was only between 70 and 90 % duty (So it only moved the solenoid between 70 and 90%).
I’ve been working with it in this way but then thought I’d see whether I should try using H-Bridge mode with one of the slave outputs on my S6 Plus. Well, I started by simply using the Slave output in the same way as before (Low Side Mode) and it works really well. Perfectly in fact, at the same frequency.
I’ve got plenty of outputs spare, so I plan to move over to using the slave outputs but can anyone explain why this is?
Is it power limitation on the fuel outputs perhaps and I’m saturating them?
Thanks in advance.
Michael.
Thanks in advance.
Michael.
