Evo 9 base map
Posted: Mon Apr 27, 2020 1:16 pm
				does anyone have a base map for a evo 9? i have a s6 plus general purpose, i have a uk fq320 hoping to do a dyno run set up this week just need a base map, (im in the middle of doing the belts and wanted to replace the crank pickup for a 18tooth one at the same time) iv been a mechanic for many years however only recently been delving into ECU setups so with regards to programing im still a relative novice.
thank you for your help
