Output tests
Output tests
Why no option ? or am I missing something ?
Re: Output tests
For future reference, an output test can be carried out by assigning a slave output to a basic PWM output. Then using the PWM output duty table to pull the output high or low.
Output tests in the normal way are not possible as slave bus communications switch off when the ECU enters test mode.
