				Latest Base Map
				Posted: Thu Mar 11, 2021 11:28 am
				by Ryan.g
				The latest Nissan R35GTR AWD Base map which matches the latest firmware can be found below in Attachments
				1.15
				Posted: Tue Apr 27, 2021 2:19 pm
				by Ryan.g
				1.15 Firmware Latest base map
				1.18
				Posted: Tue Oct 12, 2021 8:46 am
				by Ryan.g
				1.21 Base Map
				Posted: Thu Nov 04, 2021 5:55 am
				by Ryan.g
				For use with 1.21 Firmware
				1.23 Base Maps
				Posted: Wed Jul 13, 2022 2:59 pm
				by Ryan.g
For use with 1.23 Firmwares
				1.24 Base Maps
				Posted: Fri Nov 25, 2022 12:20 pm
				by Ryan.g
For use with 1.24 Firmwares
				1.25
				Posted: Fri Apr 07, 2023 7:06 pm
				by Ryan.g
				Re: Latest Base Map
				Posted: Fri Dec 15, 2023 5:54 am
				by Ryan.g
For use with 1.27 Firmwares
				Re: Latest Base Map
				Posted: Mon Apr 15, 2024 3:05 pm
				by Ryan.g
				For use with 1.28 Firmwares
				Re: Latest Base Map
				Posted: Fri Apr 19, 2024 1:09 pm
				by Ryan.g
				1.29 Base map
