				A/C pin assignment newage sti
				Posted: Wed Jul 14, 2021 1:19 pm
				by bigbeanbags
Can anyone bump me in the right direction?
Im trying to get my a/c to work on my s6 but unsure of which i/o should be assigned. Any help with the matter is much appreciated. Its an 04 sti.
				Re: A/C pin assignment newage sti
				Posted: Wed Jul 14, 2021 1:38 pm
				Have you checked the forum section for the S6 PnP pin assignments?
				Posted: Wed Jul 14, 2021 6:35 pm
				Posted: Fri Nov 17, 2023 8:56 am
				by stevenferrell
				TimH wrote: Wed Jul 14, 2021 1:38 pm
drift hunters
Hi I'm trying to connect an ecu master can expanded into can l and h on the ecu board. However I'm having trouble.
				Posted: Fri Nov 17, 2023 10:17 am
				For what purpose exactly ? I'd doubt the ECU master would be compatible ?
				Posted: Fri Nov 17, 2023 10:39 am
				stevieturbo wrote: Fri Nov 17, 2023 10:17 am
S6 cannot receive additional inputs via CAN. Is this S6?
If S7, with 2x CANbus, you can receive data via CAN and the ECU master expander can almost certainly be configured to work.
