Bosch donat style knock sensor wiring
Posted: Thu Sep 15, 2022 2:28 pm
				Hello,
I am wiring two Bosch donat style knock sensors on my S7+. My engine is 2jzgte
I am using 2 core Tefzel shielded wire. On the S7plus manual i found
Knock> B4
Knock2>B5
Knock Grounds>C1 (spliced two knock sensors ground and connect here? am i right ?)
Then which pin i can use for shield drain ?
Another question is which pin i can use to connect my radiator fan ?
TIA
Knock> B4
Knock2>B5
TIA
