Learn Maps - committing to base maps?
Posted: Sun Nov 13, 2022 11:26 am
				Hi
Does anyone know if the 'learn' maps (For idle base duty, knock/cylinder trim, WG duty etc) can be committed to their respective base map or do they just exist as separate constantly changing maps? Other ECU's I have used allow you to commit to the base map and zero out the learn map, wondered if you can do this on the syvecs.
