Latest Firmware Releases
Latest updates and support on the DI12 Module
Locked
Latest Firmware Releases for the Syvecs DI12 which have the USB Adjustment port as seen below
Re: Latest Firmware Releases
Firmware 1.2 of the Syvecs DI12 Module is attached below.
Please use the Syvecs Updater program to load the ENC file. Guide here http://www.syvecs.com/downloads/Syvecs_Updater.pdf
This Firmware is only for DI12 Modules which has the USB plug on the back of the Unit with removable HEX Plug
The 1.2 Firmware adds Scal software support to allow configuration of the DI12 Current levels and users must select Program - Defaults in Scal after programming the ENC below to load a default calibration. Adjusts can be made after.
https://www.syvecs.com/downloads/DI12_1-2-1.enc
Firmware 1.3 of the Syvecs DI12 Module is attached below.
Changes since 1.2
* Fast boost option - Boost is turned off when target current is met regards of the boost time set
https://www.syvecs.com/downloads/DI12_1-3-1.enc
Locked
