Page 1 of 2
				Accelerometer tables
				Posted: Wed Nov 01, 2023 2:01 pm
				by xr4x4ti
				I am getting my basic setup sorted.
But, am I missing something, or are there not any tables that utilize the 6 axis accelerometer?
What is the point of having it, it is featured in the description if you can't use it to modify the output duty cycle?
Thanks in advance
				Re: Accelerometer tables
				Posted: Tue Nov 14, 2023 4:02 pm
				by xr4x4ti
				Wow, not much traffic on this forum.  I even PM'ed the user that updates all of the base files and nothing.
I think I am asking a pretty simple question.  Even if the answer was, well they are just for reference for now, maybe we will make some tables in the future.
Here is an exact quote from the description:
"A 6-Axis IMU sensor is also fitted on the board to allow acceleration data to be viewed in real time or linked into strategies."
Are they referring to using the data over the CAN Buss in one of the Syvecs ECU's?
Thanks in advance
				Posted: Thu Nov 16, 2023 11:17 pm
				xr4x4ti wrote: Tue Nov 14, 2023 4:02 pm
Thanks in advance
I haven't used one myself. But yes that is what it sounds like. Can you see any accell data ?
				Posted: Fri Nov 17, 2023 1:51 am
				by xr4x4ti
				Thanks for the response.
Yes, I can see the accelerometer data when I have my PC hooked up to it and I sure if I had a Tinydash or something similar you could see it there, but I don't see a way to actually use the data in the strategy built into the AWD controller.
				Posted: Fri Nov 24, 2023 3:08 am
				by amdisthebest
				There are 15 CM2xx (2d) and 15 CM3xx (3d) tables to make almost any strategy you can imagine using any inputs you'd like.
				Posted: Wed Nov 29, 2023 7:00 pm
				by xr4x4ti
				amdisthebest wrote: Fri Nov 24, 2023 3:08 am
But are these tables available within the AWD controller itself or in the main EFI controllers that can get the data via CAN?
If it is in the controller itself, can you please explain how to access them?
Thanks in advance,
Tim
				Posted: Fri Dec 15, 2023 2:37 pm
				by xr4x4ti
				Not to sound bitchy, but does anybody from Syvecs actually look at these forums?  I tried to PM Ryan.g, no response.
Some sort of response would be nice even if it is your SOL and you can't use them.
				Posted: Fri Dec 15, 2023 2:48 pm
				It doesn't seem to get a lot of traffic. The Facebook group tends to get more responses
				Posted: Fri Dec 15, 2023 3:55 pm
				by xr4x4ti
				stevieturbo wrote: Fri Dec 15, 2023 2:48 pm
Thanks, I will check that out!
				Posted: Fri Dec 15, 2023 3:56 pm
