Single Cylinder EGT average
darksyde
Post by darksyde »
I am running 6 K-type thermocouples on a V6 engine into a CAN-Bus transceiver. I am receiving these as user definable sensors on the F88.
Is it possible to build an average math channel from the the individual cylinder on each side to use it as egt1/egt2 channel for lambda-target correction and ALS-functions?
Re: Single Cylinder EGT average
you just use TIT1 and TIT2 but assigned to EGT1 and EGT2
if you want good type k for this application reach around to me
