Latest Base Map
The Syvecs Lam2CAN is an 8 Channel Laboratory Grade NTK Lambda sensor interface with comprehensive onboard fault logic. It also includes dual dedicated exhaust pressure sensor inputs enabling compensation for the effects of exhaust pressure on the lambda measurement. Data from the Lam2CAN is then transmitted via CAN to provide fast and accurate data to engine control units and external dataloggers.
Locked
Latest Base Map
Latest 1.10 Base map for the Lam2CAN attached below
Lam2CAN Base Map.SC
(74.36 KiB) Downloaded 1042 times
Locked
