Lam2CAN DBC CAN File
The Syvecs Lam2CAN is an 8 Channel Laboratory Grade NTK Lambda sensor interface with comprehensive onboard fault logic. It also includes dual dedicated exhaust pressure sensor inputs enabling compensation for the effects of exhaust pressure on the lambda measurement. Data from the Lam2CAN is then transmitted via CAN to provide fast and accurate data to engine control units and external dataloggers.
Please fine below Syvecs LAM2CAN DBC File
www.syvecs.com/downloads/Syvecs%20Lam2CAN.dbc
