				Pwm fuel injector
				Posted: Sat May 11, 2024 9:18 am
				by Lqqk
				Is it possible to use a fuel injector (high impedance) with the Syvecs wmi? Have wondered based on the manual images?
				Re: Pwm fuel injector
				Posted: Tue May 14, 2024 7:23 am
				by Ryan.g
				yes no issue at all, i would say an injector is better than most valves on the market
				Posted: Wed May 15, 2024 2:50 pm
				by darksyde
				I want to use two injectors (one per bank on a six cylinder) with a F88.
Would it be possible to set up WMI as secondary injectors and assign the three cylinders of one bank to one injector output?
I would like to keep it syncronized to the crank, so the cylinders are getting an even distribution of wm.
				Posted: Thu May 16, 2024 11:43 pm
				no
				Posted: Sat May 18, 2024 9:12 am
				by darksyde
				So I am going to assign secondary injector outputs 1-6 to six outputs and wire three outputs for one bank together for the injector. Same for the other bank.
As they are open collector, can I just put the three outputs on one injector or should I use a diode in-line on each output of the ECU?
				Posted: Wed Jul 10, 2024 10:35 am
				by lilycollins9x
				Yes, it is possible to use a high impedance fuel injector with the Syvecs Water Methanol Injection (WMI) system. The Syvecs WMI system is designed to work with injectors that are typically used for water methanol injection purposes, which are often high impedance injectors.
Monkey Mart
				Posted: Wed Jul 17, 2024 3:41 pm
				by Lqqk
				Started to play with this - any suggestions what frequency is the right starting point in the settings for a fuel injector?
