				Glossary and definition of parameters being logged in SView
				Posted: Wed May 29, 2024 3:17 pm
				by PeteJ
				Moving this post here from another area as it is more software related than hardware.
I am trying to track down some issues with a car going into limp mode but the parameter names and data logged in SView are rather cryptic. Is there a glossary somewhere that shows what the logged values are? For example I was told that bt and btmax are the ECU temperature which is not very intuitive.
				Re: Glossary and definition of parameters being logged in SView
				Posted: Wed May 29, 2024 5:46 pm
				Then log Limpmode and it will tell you why
				Posted: Thu May 30, 2024 12:33 am
				by PeteJ
				I am already logging Limp mode and know what has triped.
The problem comes in when trying to troubleshoot an issue. For example what parameter is an "actual" and what is a "target". I purchased the car with the Syvecs already installed, hence why I'm asking for a glossary/definition of what the parameters are in SView. I'm not even sure if the parameters have a standard naming convention or not
				Posted: Thu May 30, 2024 9:54 am
				Most are fairly self explanatory, so what is limp mode saying then ?
				Posted: Thu May 30, 2024 1:37 pm
				by PeteJ
				Yes, many are easy to understand but others are not. It was a lean condition due to a different issue. Regarding my request, I used that as an example.
I'm not asking for help in troubleshooting, I'm simply asking for the parameter definitions.
				Posted: Fri Jun 07, 2024 10:46 pm
				by nmerdan
				I did try to maintain a list here, so it may be useful:
https://syvecs.wiki/basics:abbreviations
