2007 STI DCCD Controller
Posted: Tue Jan 26, 2010 6:13 pm
				I'm driving a 2007 STI, which has a 15:1 steering ratio rack with a steering angle sensor input for the OEM DCCD controller.  This sensor is located in the steering column.  I'm intending to change to a 13:1 quick-ratio steering rack (used on JDM STIs), and have concerns that the OEM DCCD controller may not work as accurately as it did with the 15:1 OEM steering rack, given that now, with the same angle of steering input, the front tyres will actually turn more than before.  In a sense, the DCCD controller will now underestimate the driver's intended turning radius.
I'm wondering if there is a difference between the steering angle parameters within the JDM DCCD controllers and non-JDM DCCD controllers to accomodate the differences in 13:1 and 15:1 steering ratios? If so, will the S6GP allow me to fine tune or re-scale these DCCD steering angle parameters so that the DCCD controller will not mis-read the driver's intended turning radius?
