WB possible failure
gctech
WB possible failure
Post by gctech »
Hello Guys ,
I attached a datalog in which the WB sensor does some random dips , but does not do it all the time , I can make a run and be clean then the following run will dip rich and the fuel pressure will drop some time triggering a FP Trip
thanks
2026-03-10 15-18-23 plus 0h00m00s S7#30526 WB Condition.SD
(957.48 KiB) Downloaded 75 times
Re: WB possible failure
Everywhere in that log it looks to be working ?
Exactly where do you believe it is not on that log ?
Although fuel pressure does seem a bit odd. What engine is this ? A normal port injection or is there direct injection too ?
If normal port injection, your base fuel pressure of around 5 bar a little high, but fuel pressure increases far more than 1:1 with boost. Normally on a port injected boost referenced setup relFP1 should be a fairly static value, yours is all over the place.
If it's direct injection, it's not something I've any experience on. Although I do see a FP target and your FP does seem to track that well, so presumably it's ok ?
But Lam1 seems to be reading at all times, no actual drop outs, the line is smooth etc and seems reasonable numbers ?
Only after seeing your post on FB...
I see the areas now you refer to. Does look odd...although also why is FP dropping too ?
Could be an electrical gremlin of some sort. Fuel final does drop too in response to thinking it is rich.
