Hi all,
I’m trying to confirm correct Bosch LSU 5.2 support and linearisation on a Syvecs S8 TSI plug-in for a VW 2.0 TSI CAWB.
The tuner I bought the Syvecs from told me that LSU 5.2 is what they were using on Syvecs VAG installs, so I’m trying to verify the correct setup and get a known-good starting point.
In SensorDB I can currently see:
LR NTK Lambda (L1H1)
NTK LZA-09E1
S6Plus LSU4.9 G125 Update
I do not see an explicit LSU 5.2 entry.
What I’m trying to confirm:
Can the S8 TSI plug-in correctly run a Bosch LSU 5.2 as the primary lambda sensor?
Does anyone have a known-good LSU 5.2 linearisation table / curve for Syvecs they can share?
Is there an official Syvecs base calibration for LSU 5.2, or is the usual starting point the S6Plus LSU4.9 G125 Update entry and then calibrating from there?
Has anyone here already run LSU 5.2 successfully on a Syvecs VAG install, and if so, what input configuration / linearisation did you use?
Any confirmed data, screenshots, or known-good values would be appreciated.
Thanks.
Bosch LSU 5.2 support / linearization on S8 TSI plug-in
Jump to
- ↳ General Syvecs Chat
- ↳ S6 GP/PnP Technical
- ↳ S6-I / S6Plus Technical
- ↳ S7-I / S7Plus Technical
- ↳ S8 Technical
- ↳ S12 Technical
- ↳ Syvecs Bluetooth Module
- ↳ Software
- ↳ Calibrations
- ↳ Technical Deposit
- ↳ Projects
- General Technical Forums
- ↳ Subaru
- ↳ Mitsubishi
- ↳ Toyota
- ↳ Nissan
- ↳ Porsche
- ↳ Dyno Talk
- ↳ Track Days
- ↳ VAG Technical
- Expanders
- ↳ X10 (Legacy - Gen1)
- ↳ X10 Gen2 Expander
- ↳ X20L Gen2
- ↳ X4 Gen2
- ↳ OEX - Oem Ecu eXpander
- Syvecs AWD Modules
- ↳ General Questions
- ↳ Porsche 991.1 / 991.2
- ↳ Porsche 997.1 / 997.2
- ↳ Huracan / R8
- ↳ Nissan R35GTR
- ↳ Infiniti Q60
- ↳ Yaris GR Gen1
- ↳ CorollaGR / Yaris GR Gen2
- ↳ Generic AWD Module
- ↳ Syvecs KT8
- ↳ KT8 Rev3 Standalone
- ↳ Syvecs Wifi Module
- ↳ Syvecs WMI Module
- ↳ Syvecs DI12
- ↳ Syvecs Lam2CAN
- Syvecs Dashes
- ↳ Syvecs TinyDash
- ↳ Syvecs D5 Dash
- Enhancements
- ↳ Feature Requests
- ↳ Request for Comments
- JT Innovations
- ↳ Toucan Display
- ↳ General
- Feedback
- ↳ Website feedback
