Hi
Question for Pat
After getting the ECU and DASH (race-tec dash2) working together Ryan mentioned that we could input the oil pressure gauge to the ECU i was hoping that you could tell me what pin's to use it is a 93-96 plug and play.
Also was wondering if you had the wiring for the new age pencil coils as this seems to be the way to go. SORTED coils
many thanks to you and Ryan for the help over the last few weeks.
Cheers Stewart and Bod from TFS Racing.
oil pressure sender
Re: oil pressure sender
Stewart,
Any spare AB, AU or AV input will do. Each PnP ECU calibration should have in the Calibration Comments an I/O list, that is to say what each S6 input and output is connected to on the OEM wiring. Just choose one which isn't already used by something else and splice the new signal into the OEM loom (if memory serves, two of the AB inputs are connected to the Select Monitor signal wires, for example).
