				Logging to a PC
				Posted: Mon Oct 18, 2010 11:30 pm
				by Andy Blyth
				Hello!
Are there any plans to implement logging directly on a PC with the Syvecs ECU?  I'm currently researching to find a standalone ECU that meets my needs.  So far, the Syvecs is the only one that does not offer PC logging!  It's quite a weak point in my eyes - especially given the unusually high bandwidth link available.
Andy
				Re: Logging to a PC
				Posted: Tue Oct 19, 2010 6:14 pm
				by secure
				Hi!
I don't know if you have special plan or requirements  but you won't need that really.
1 mb is enough to keep 'enough' data.
The biggest file I have downloaded for 1 session  was 535 kb.
If a PC connected to ECU you can still download logs and clear log memory for just one click.
cheers.
				Re: Logging to a PC
				Posted: Thu Oct 21, 2010 12:58 pm
				by Ryan.g
				Hi Andy
Problem with computer logging is its just not fast enough compared to logging onboard also if a computer freezes or has an issues while you are logging it is lost. In motorsort and high end performance cars this risk of losing the log cant be allowed.
Its just as quick to pull the logs of the unit each time than it would be to do them on the pc
Ryan
				Re: Logging to a PC
				Posted: Mon Nov 08, 2010 10:12 am
				by Austrian Impreza
				I was only able to log a maximum of 20minutes (415kb), is that really the maximum, or do I have to clear the memory to allow any longer record?
Btw. how many files can it store, is that only restricted by the allowed byte or is there a number of files e.g. 3 files maximum?
