Injection End Angle
Posted: Sun Sep 04, 2011 11:27 am
				All,
I have had Tip-In issues from the beginning and no matter how I changed the Transient Fueling properties it always felt hesitant on blips from Idle.
I noticed that my Injection End Angle was set to 540 degr. as that was in the basemap from the start and I didn't fiddle with it.
Afterwards I got some other data and I noticed an Injection End Angle of 360 degr. was used. I changed the 540 degr. for 360 degr. accross the whole RPM range and was pleasantly surprised with very crisp response on blips straight from Idle. AFRs have changed though and I believe I need to redo a bit of Fuel mapping.
The question is though how to properly derive the best Injection End Angle for each RPM breakpoint. Am I correct in saying the Injection End Angle should be different based on Injector size as the Inj. ms. will be very different for the same requirement making the start angle completely different vs. the same eng angle? I believe the best Injection End angle would be to have the injection started when the Intake valves open so atomisation is at it's best due to piston speed, etc. Spraying too early or too late may prevent Fuel from being directly drawn into the cylinder making it going out of suspension and onto runner walls. I also understand that Injection End Angle does not make ANY difference when IDCs are nearing 100% as the injectors are spraying continuously and do not stop.
I am looking forward to some more in depth tech info on this as I believe this is the key to get the best response and also probably can enhance fuel consumption A LOT. Thanks in advance!
Best Regards,
Jasper Kopinga
CS Racing
Taiwan.
Best Regards,
Jasper Kopinga
CS Racing
Taiwan.
