closed loop lambda problem
Posted: Sun Oct 23, 2011 7:20 pm
				The application is my newage impreza with 2.5 and GT35R.
I have installed an innovate LC-1 and wired the 0-5v output to AN11. Linearisation is set up and I can see the Lam1 result on the ECU which correlates to my innovate gauge.
I can also see the cll %error, however the problem is that the ECU does not appear to be adjusting fueling to hit target despite the error being visible.
The delta is within error ranges and cll is enabled when this happens.
I have also noticed that the cll integral and propotional tables do not have a dynamic white vertical tracer line as is the case with int and prop tables on closed loop idle for example and I wonder if this is related.
Anyone else noticed this or have any thoughts?
