Cold "cold start"
Posted: Tue Jan 31, 2012 9:44 am
				To my surprise this morning my car refused to start. The engine is 2004 USDM EJ257 with drive by cable throttle body from EJ207 running Syvecs S6PNP.
Outside temperature was -16 C or a little bit less.
The engine cranked OK - a little bit slower, but perfectly normal. However, the engine did NOT even try to start. After some useless cranking the battery began slowly to give up, so I hooked my notebook and started SCal. Syvecs read 0(zero) rpm during cranking. I opened Sync Log and crank/cam sensor data seemed fine to me.
The engine jump started easy.
Can you give me any ideas how to fix this issue?
I don't think my battery is dying because in the beggining I had perfectly nice cranking rpm given the temperature outside - my guess would be aroung 180-200rpm.
Thanks!
Thanks!
