				Issues :0
				Posted: Sun May 13, 2012 7:01 pm
				by jonnyc
				I were just trying to connect a gear position sensor to pin 37 , for some reason iI couldn't get the syvecs to read the voltage change,  then under cOnnection it says connected but not in sync?!  Also now I have noticed it says it's booted to boot code 1.2.  Have I murdered it?!
 note battery were a little low
Sorry for the essay but hope to hear back soon!
Jonny
				Re: Issues :0
				Posted: Sun May 13, 2012 10:32 pm
				by secure
				I think you have connected it into a wrong input. Find a suitable input(bipolar,unipolar,voltage or resistive input) according to position sensor you have.
				Re: Issues :0
				Posted: Sun May 13, 2012 11:44 pm
				by jonnyc
				hi, i have the same sensor in another car on the same type of input (working one is in AN04, this one is in AN03) would you recomend pullin g out the oins and see if it still starts working -  as the pumps dont prime at the moment! :S
				Re: Issues :0
				Posted: Mon May 14, 2012 1:19 pm
				The answer to why it won't boot will be in the status messages in the bottom right hand corner of the SCal display. Most likely your sensor setup is asking for an input configuration that the ECU cannot provide, eg input type set to THERMISTOR on an AB input will cause it to fail to boot. Only 5V and and 5V BIPOLAR are supported on those pins. It is a SOFTWARE check that is making it fail to boot, you should not need to do anything to the pins. It is also possible that the flash failed due to poor battery voltage; if this is the case then simply charge the battery or put a booster pack on it and flash it again. Of the two possibilities the latter is somewhat less likely.
				Re: Issues :0
				Posted: Thu May 17, 2012 8:39 am
				by jonnyc
				got it sorted now, it was a due to the gear input i had put in.... it was conflicting with gear form wheel speed, thanks pat & Paul at zen (pavlo)
