some info require about syvec ecu
Posted: Thu Aug 02, 2012 9:58 am
				hi all i'm new on here,
i've bought a evo 8 which has a syvec ecu, not 100% sure if its a s6 or s8. its a complete ecu not just the board so i presume it was s8 from the pictures i can find of both ecu's, but i'm unsure??
can it be a s6 ecu if its a complete unit not just the board?? mine has 8 switchable maps if that tells you anything?
i've downloaded the software to connect the ecu to my laptop, i had a quick look last night but i couldnt work out how to compare the maps on the ecu. there is 3 different maps 1.6bar 1.8bar and 2.1bar
do i need to have the switch inside the car in the correct position to look at that map then change it and see what the other map is?
how do i save the maps thats on the ecu to my computer?
if anyone can help that will be great.
