i'm just starting to get towards the end of my build now and recently purchased a s6pnp off a lad with a blobeye,so sent it off to charlie so it could be converted to 3 plug to fit my v3 sti 97'.
i'm hoping someone could shed some light on a problem i've come across tonight,basically the car is at a point where it can be started to make sure it does
so i fitted the s6 and put ign on and had a lot of buzzing which i traced to main relay box on n/s inner wing and no 'check engine light',and no fuel pump prime either.
thought i'd try the standard ecu board just to see if it happened with that on and the car fired up on the first turn with no buzzing and everything as it should be,albeit it wanted to rev straight up as basically nothing is fitted on the induction side of things and the obvious no maf etc.
if someone can shed some light on this it would help no end.
Tim
