Silicone joiners with air temp sensor boss
Posted: Wed Nov 28, 2012 8:36 pm
				If anyone's interested, I now have some silicone reducers available with a moulded-in 10mm boss, ready to accept most common air temp sensors. This should make Syvecs installations that little bit easier, with no need to drill holes, and/or no need to make use of epoxy resin (with a good sprinkling of luck) to keep the sensor in place
Two different sizes:
These are made for us by SFS, so there should be few concerns about their quality
£49.99+VAT each.
- 70mm-to-63mm (standard Subaru throttle body to smaller FMIC pipework such as Hybrids)
- 70mm-to-76mm (standard Subaru throttle body to larger FMIC pipework such as APS or Hyperflow)
£49.99+VAT each.
