				Support for SR20 CAS sensor
				Posted: Thu Jan 17, 2013 1:02 pm
				by Slowie
				Hi
I downloaded the calibration software and S6 example calibration to play around with as I hunt for a suitable ECU for my car.
I see the Skyline CAS is supported, and I don't grasp all the settings in the custom trigger configuration. Is support for the 4-cylinder SR20 CAS sensor available?
Thanks in advance.
				Re: Support for SR20 CAS sensor
				Posted: Thu Jan 17, 2013 10:10 pm
				by Jez
				Not at the moment - we usually swap the CAS disk out for one similar to this:
http://www.ebay.com/itm/AEM-30-8760-CAS ... 0725856700
				Posted: Fri Jan 18, 2013 5:19 am
				by Slowie
				Yes, that's easy enough to do.
Thanks.
				Posted: Tue Jan 22, 2013 9:18 am
				by Mark@Abbey M/S
				Jez,
that disc works well then? or would it be better to go 36-1 with a phase sensor? Got a Sr20 project on the go @ the moment and looking at running it on a S6.
				Posted: Tue Jan 22, 2013 9:44 am
				by PQatPIT
				Mark@Abbey M/S wrote:would it be better to go 36-1 with a phase sensor?
The best would be a missing tooth trigger disc on crank, and one phase tooth on cam. This needs a trigger disc and sensor install but if higher revving engine then it makes a difference.
				Posted: Tue Jan 22, 2013 9:47 pm
				by Jez
				The disk worked ok on my engine - I didn't attempt to measure any jitter caused by the chain flapping about / play in the cam/cas gear.
A proper crank wheel and cam phase setup would, in theory, work better - but I found on my car the disk was adequate.
				Posted: Sat Mar 21, 2015 8:27 am
				by simigeri
				Could somebody share a cal file using this AEM trigger disc?
				Posted: Wed Sep 23, 2015 9:06 am
				by Slowie
				Hi
Also looking for a calibration for the AEM SR20 disc please.
I looked at the RB26 one posted earlier for ideas, but need the angles for the SR installation.
