FlexFuel sensors
FlexFuel sensors
FYI we have flex fuel sensors in stock, complete with 1.5m or 4m cables (engine bay mounting vs. boot mounting) and available with or without -6 fittings.
These are a great addition for any car running meth or ethanol fuel mixes as you no longer have to accurately mix fuel at the pump - the Syvecs flex strategy will interpolate between a pump fuel and a methanol/ethanol map seamlessly.
Contact us for prices.
Re: FlexFuel sensors
Is the General forum okay for pimping stuff?
Well...this is the JTi section of the forum so I assume it's OK. If not, I'm sure I'll get told.
aaaah i just saw the "general" !
Carry on!
Do you have them in stock ready to send?
pavlo wrote:aaaah i just saw the "general" !
No problem :)
pavlo wrote:Do you have them in stock ready to send?
Absolutely 8-)
CHRIS S
Post by CHRIS S »
When i drain the tank and put pump fuel in after an event,
will this automatically adjust the mixture or swap maps?
CHRIS S wrote:When i drain the tank and put pump fuel in after an event, will this automatically adjust the mixture or swap maps?
It measures alcohol content - so if you're swapping between race fuel and pump fuel, or even 95RON and 98/99RON then it won't "flex" properly, as I understand it.
The methodology is to map using your base pump fuel, then map with pump fuel + x% alcohol and setup the Syvecs strategy so it "flexes" between those two maps.
As an example, my own car was mapped on VPower, then on Vpower+15% methanol. As long as I don't ever exceed a 15% mix, the sensor and the Syvecs strategy mean I don't have to be overly accurate when adding methanol to the fuel.
CHRIS S
Post by CHRIS S »
Hi Tim
What I was getting at is I Race the Car on VPC85 then after the event I drain it and run pump fuel threw the motor and injectors ect
Will it automatically adjust the fueling?
CHRIS S wrote:Hi Tim
If the ecu has been tuned correctly, then yes it should allow you to run pump through the E85 fuel without you making changes at the time.
