				ballast resistors
				Posted: Tue Oct 15, 2013 1:10 pm
				by ford racing
				hi iam going to be using low impedance injecters on an s8 and need to know how to work out what size ballast resistors to use.thanks in advance
				Re: ballast resistors
				Posted: Tue Oct 15, 2013 2:49 pm
				by pavlo
				http://uk.rs-online.com/web/p/panel-mou ... s/0160714/
If mounted on a heatsink (ie cool spreader plate) then 15w will probably also be fine.
				Posted: Wed Oct 16, 2013 12:12 am
				Or maybe pick up some resistor packs from an OEM car.
Some Mitsu Evo's use them, Toyota MR2 turbo, old Honda Civics and perhaps others
				Posted: Wed Oct 16, 2013 10:51 am
				by PQatPIT
				I thought that S8 can control low impedance injectors without any extra resistors. The pinout pdf says 10A Open Collector output.
				Posted: Wed Oct 16, 2013 11:05 am
				by pavlo
				Yes it can. I've not found it to be 100% reliable, I described my experiences and advice on another thread.
