S6 PnP and wasted spark
Posted: Thu Feb 20, 2014 8:40 am
				Hi I have an 99 Sti type r running an S6 PnP. I have converted to newage coil on plug and am running wasted spark. The car runs smoothly,there are no misfres etc but it feels flat and is down on power. I changed turbos at the same time and initially thought it was turbo related but have now ruled this out. I would like to rule out if it could relate to the coil on plug conversion.
I did not change any pin assignments with the mod given both the old and new configuration are wasted spark. I have set dwell time to 4 ms. Are there any other settings I should be considering? Cheers.
